I've experimented with it, and my experience is similar to the tracks Dave pictured. As you wrote, the difference is mainly in leeway. The heading doesn't change that much but the COG does. Your heading and sail trim to windward are largely limited by the apparent wind angle. Your boat speed (through the water) will also improve significantly with the CB down, unless running DDW.
