… the Out-Islands and southern Bahamas to be fairly empty in January. From the middle of February to Easter (if it comes early) there will easily be 15 to 30 boats in that harbour, short season for them. I hope Jackie & Mike at the Breeze are still doing well. I can't remember when it is, but for the past several years there is a large flotilla from GT that comes over and spends several days, you might want to avoid that time, there's usually 60 boats or so ! Give us a report on the weather and the Fronts this winter, it appears from Parker's reports you have had your share this winter so far, any nasty Fronts ? Which isn't really unusual, it does blow in the Bahamas, but ample opportunity to move south & east if the Fronts are frequent and not that bad, which appears to be what you've been able to do without much problem ? Cheers, John
