I had this happen once a long time ago.
It turned out to be the shift lever cable slipping in it's little clip. I don't know the linkage configuration they're using but on mine I replaced the cable end clip with a new SS one and it worked fine. It turned out that the little bump that fits into grove on the cable had rusted off allowing the cable to slip. So, it might be something simple like that.
