same deal Larry
The new tank is in with some difficulty and bloodshed. Naturally the same brand/model as the original has a different mounting hole configuration.......sigh. I also took the opportunity to replace the cooling water fittings on the engine block. Rusty fittings do not make for a trouble free outing.
Downside of the weekend is that there are several owners who have no business being boat owners. They have done nothing to prep for spring launch including removing the shrinkwrap so are holding up the rest of us. The upside to that is the DAHL diesel filter is still leaking even after a rebuild Friday so a new Racor is on order. That will go in Friday, launch Saturday if we can get some boats/owners moved.
