One less hole in the boat
Just getting around to insalling new Raymarine depth sounder, my old antique had a plastic pipe epoxied in the bilge with the transponder and no hull penetration. I took my new transponder and put some fresh water in the forward bilge and tried it. Worked perfectly so I will mount it back in the old pipe add a little mineral oil and one less penetration on Tappan Zee!
