When installing our new engine, (and the previous one) I removed the PSS seal and inserted a bushing I had machined in the shaft log (aka stern tube) to hold the shaft in centre while aligning the engine.
This must be done on shore of course.
Anyone have experience checking he alignment in the water? Is it sufficient to just block the shaft up in a Vee block before disconnecting from the engine?
