Not noisy at all...
In Response To: Noisy ZF 25A transmission ()
I can't even hear it above the engine noise. The only thing I hear is a slight clunk when it goes into gear and that may be the Maxprop hitting the stop. If it came with your Beta they should have tested it before you got it. I trust that you did put transmission fluid in it?
