We measured back pressure on the old engine
In Response To: Why do you believe that? ()
which was smaller and hence generated a little less gas flow.
It showed a higher pressure than Beta recommend.
We discussed it with Beta before buying, and they said our exhaust looked fine to them
Brian Woloshin has a smaller exhaust of similar design to us on his 50HP Beta that runs fine. He suggested we check the pipe itself since he had experienced a problem with one partially delaminating, and blocking flow in the past.
