We had a similar problem. It was the antenna.
On our Milltech the connectors are different than on the VHF but I had one of those little short emergency antennas and I used it to test the AIS. BTW my installation is almost exactly like yours but without the solar panel. Once I changed out the antenna it went back to working the way it should. The antenna is replaced it with had it's own cable built-in so it could have been either the antenna base of something with the cable.
