Return to Index
Read Responses
You need ice, Dave.
In Response To:
I bought an ice pick 20 years ago.
Must have on board items:
No vise-grips?
Books, lots of them
Joshua Slocum said the same thing Chris
Sharing books
Family nostalgia. Drawings, notes to each other, tiny artworks.
And where the hell do you find ice that needs a pick anymore? I can
We make our own ice blocks. Small ones
I use a rubber maid dish pan when I'm here at home. Makes about an 18 pound block
All the marinas in New England and NY
I got a 20 lb block in Passcagoula Miss you could read through
There's a half a ton of block ice on my dock right now.
Tom, wouldn't it be easier to just install refrigeration?
I suppose. But I'm going the other way, charging less-sailing more.
Nothing wrong with that. I suppose
I freeze gallon jugs of water
Do the jugs split from expansion?
Only if you don't leave some room. Just don't fill them totally
I pour some water off before freezing...
You need ice, Dave.
I trust in SeaFrost but carry a block.
The list would be too long
Yes Dan! A microwave! Denny uses
A back-scratcher. Cheers, John
Pie plate...
A "Flopper stopper" or actually 2
The other hull(s)
That's funny!
That is pretty funny. We thought about
No lobster crackers? Use a winch handle... or a hammer
