Maine-
I want to keep the install simple in that I don't want to add an additional panel. Also, the proposed shore power inlet is 15 feet or so from the breaker panel. Can I somehow combine both 30 amp incoming shore power lines to a single "master" breaker, and then tap off that one for the A/C breaker that I would add to the panel (I have room for several spare breakers)?
Thanks.
Rodd
PS Thanks Brian and Dave for additional input!
