Return to Index
Read Responses
You might also check your hot water heater connections and hoses.
In Response To:
Diesel Cooling System
I've seen bleed valves, hose clamps, etc. with a "little" leak that essentially goes un-noticed.
If the heat exchanger was leaking, I think you're coolant level would rise.
good thought
Testing
another good thought
It is possible (but not very likely) that its the heat exchanger in the hot water heater...
It could be evaporating, too -- leaving a residue.
Water Heater is 40 years old
I'd check it first, just to see if it's something simple, Eddie.
Do you flush the cooling system and put in new coolant, much?
Yes, loss increases with running and no steam that I see
On your expansion tank where the cap
Sorry, Tom already addressed this issue.
