..make sure the inlet is on the bottom. If installed horizontal, make sure the flappers hang down. Looking through the Bosworth literature, it's amazing the accessories available - alternate inlet/outlet fittings, different valves (including one they call a 'duck-bill' - like a 3 lipped joker valve). Not sure if you can custom order a pump with the desired valves and fittings or not..
