Chilly at night but 40*'s. Tucked up with Big Bertha I'm warm enough until get up time. Nearly completed solar panel install which with two new Lifeline batts should enable running furnace/fridge mostly at will. House wiring has been redone with larger wiring, power drop from panels taken into account, MOSTly done but still clean up, occasional set of this or that. An example is I have to finish setting the cable clam on the roof with the four panel wires passing thru the overhead.
Gotta tighten up the springs that help lift the top, the solar panels add 45 lbs'ish to the roof. HEAVY lift without adequate spring help.
Desert work. Oh my.
