Return to Index
Read Responses
If its the same case, it was a very experience sailor in the Chesapeake (from Solomon's Island)
In Response To:
Interesting solution but...
I if you do use one of those units, I'd make sure you have a number of functioning CO detectors.
How big is your water heater?
We have a 12 Gal unit...
We had a 6 gallon heater on...
I'm not sure about promoting waste.
The old adage comes to mind...
6 gallons
Tankless option
I had a Whalter about 30 years ago. It worked great until
LOL- 2 quart, sitting on the stove. Then gets poured into a pump up shower
I have one of those Duckworks pumps too
I made one mod to the hose set up that I've shown to Chuck (the duck)
Charlie, I love that rack for the pump. Well done!
Charlie, I am afraid you would be horrified...
Thanks. Here's a pic of the mount without the tank in it
I'm assuming that a strip of PVC pipe bent to the radius?
Yes. 6 inch pipe opened to the right radius,, using a heat gun
I'm happiest showering on deck, Charlie.
On Tehani, I sit in cockpit floor, wioth the cockpit cushions flipped back against coamings
The secret to showering on a sailboat is the "floor
Is that the head parked next to your shower?
Nope- just a bucket. Boat has an MSD plumbed for pumpout
Our 6 is never enough. But this is your generator steering you, Bruce.
6 gallons
I installed a new 40 liter Isotherm in 2008 ...
