If your alternator has stopped working and
In Response To: Alternator diodes ()
you feel that the bearings are OK then you can chance out the diode tree quite easily. Usually you can take the case apart and they are sitting right there. It just a couple of screws, remove and replace. I've done it a few times in the past in out of the way places and most auto parts stores kept them in stock. There are several books and Utube will have a video on checking an alternator.
