Re: Anyone using Barnacle Buster?
In Response To: Anyone using Barnacle Buster? ()
I ran it through the Yanmar cooling as part of the winterizing on previous boat will probably do the same on the old Perkins. I have also used it to descale and remove hard water stains in the toilets and other uses. Non-toxic stuff so a good rinse after is all it takes......
