..to your earlier post, I guess no one has a source to suggest. Perhaps you should find a way to get along without it in the short run until you find a replacement. I suspect the switch is normally open, closed when in neutral to allow the starter to engage. Perhaps just disconnect the wires from the switch and connect them to each other to allow the starter to work? If the switch is normally closed, just disconnect one lead.
