Re: Windlass broken
In Response To: Re: Windlass broken ()
My guess is that since many windlass companies essentially use starter motors for power the "bearing" you are talking about is really what in the old days was called a Bendix, but was really the 'starter drive' within the motor. It was sorta like a clutch that would only grip and turn in one direction. If that is the case, then it would be pretty easy to dismantle the motor and replace just that part. I did it numerous times to older cars I normally drove.
Not that it does you much good now, but that is just one of the many reasons why I spent the money and bought a Lighthouse 1501.
Eddie
