Just surged up to 69 and is falling again, but 68 degrees this late in November is down right freakish. Usually this time of year the water temp is in the low 60's. Enjoy El Nino folks.
BTW I get this data from various buoys that are part of a water monitoring system set up in various locations around the US... the system is called CDIP.
The water in the PNW... uh, that's cold, currently reporting 55 degrees F at Gray's Harbor, WA.
