I need to haul one afternoon, sit in the sling overnight and launch the next morning. Looking for a yard in Buzzards Bay that will ... be able to get my Tartan 40 high enough so I can let my Centerboard all the way down to paint that and also get up into the Trunk to paint that. I'll need a Lift that'll get me a minimum of about 12 feet off the ground, she draws almost 9 feet with the Board down.
Is there a Yard that'll let me do most if not all this work ? There will be a bit of grinding and sanding, and some painting.
I could also do this in Southern Maine ...
Thanks, cheers, John
