Return to Index
Read Responses
Frog tape....
In Response To:
Is that Green Frog tape? I find it thin and easy to tear if you leave it too long.
Frog Tape is intended for latex, I've seen some bad results with solvent based paints/varnish.
Varnish project ... When to pull the tape ?
Re: Varnish project ... When to pull the tape ?
Frog tape....
Yep.
hmmm ... Don't think it's Frog Tape ...
Re: hmmm ... Don't think it's Frog Tape ...
Color was what made me ask. I pull away low to the flat surface and about 45*.
Good suggestions ... pull flat, away from the tape and at a 45 angle. Thanks ! Cheers, John
