I think the seal is your only worry, and you will have that worry no mater what you use for the top.
Gene, If I'm not confusing you with someone else, you have an Orion and are in the Seattle area. Is that correct? I'm in Anacortes, if you're ever up this way, look me up and we can compare boats and talk about cruising in BC.
