Return to Index
Read Responses
Re: Do you have an inverter?
In Response To:
yes, but not in use
ground fault/ stray current
Re: ground fault/ stray current / Frist, put your meter between the negative post and the negative
Re: ground fault/ stray current / Here are are some numbers to shoot for:
When you say, "not in use", do you mean it's a clip-on or plug-in?
Re: When you say, "not in use", do you mean it's a clip-on or plug-in?
