A couple years ago, I called SeaFrost with this exact same question.
They told me to mix "5 parts water to one part Prestone."
I didn't like the idea of using ethylene glycol because of its toxicity, so I substituted propylene glycol.
I tested the resulting solution in my freezer. You want something that turns slushy at the target temperature, around 20 degrees. That's exactly what it did.
-tk
