Return to Index
Read Responses
Backpack foam, those 1/2" thick often blue foam pads, easy to cut to fit, can lay in or glue in...
In Response To:
Hull and bunk insulation
The under berth cushion wants air flow under. OR...quit fooling around and breaking a sweat!!
We have it under the v-berth cusions.
Er, that's cushions, though I'm sure you knew that.
We use Reflectix Bubble Pack Insulation
Hypervent works for us.
Re: Hull and bunk insulation -The key is to block water vapour
Re: Hull and bunk insulation- on the locker
Watch mildew...
I stumbled across a good article about hull insulation
