Tom,
No, I'm going to build a cradle under the mizzen mast to "nest" it in. Does that term only apply when you cut a dinghy into two pieces? If so, I've been using the tern wrong for years. I carefully measure to make sure I cut fit it on my stern deck, which is totally flush. I've always wanted to be able to take a small sailing dinghy with me when I'm cruising.
