I think the product appears to work for stucco well. I asked what they will be doing in terms of preparing the surface, number of coats, etc. From the spec sheets it appears to be necessary for each coat to be applied 14 mils (wet) and at least 8 mils when dry.
Beyond that, I asked the painter about the metal, wood, etc. painting -- the Loxon XP clearly isn't applicable for those.
Thanks for your responses.
