Um..hate to tell you..transformers do not change cycles..
only volts..step up or step down..you need a motor generator set..a 50cycle motor runs at 50 * the number of poles and is mechanically connected to a generator turning at 50 cycle speed and makes 60 hz...and it is reallly tough to do that...
