Return to Index
Read Responses
How did you prep before painting...
In Response To:
Fresh paint works well too. Cheaper than a steamer. ;)
Or did you lay the paint right down on top of the dirty surface?
Warning: post that sounds like informercial ahead
Careful with that next to teak, plywood, and sealants (nm)
Prep
Careful with that 202
Agree -- always use chemical-resistant gloves
Same thing happened to me ...
and all that solvent was "better" than steam?
Well in my case I had removed a built-in factory tank
I was putting a new coat of epoxy on the non-skid
