When we installed our SeaEra went with the optional double switch, upper rocker switch is normal flush activiting both intake pump and macerator/outlet pump. Bottom switch seperates the functions, push one way and intake water only to fill the bowl, push other way and only activates macerator which then allows a dry flush.
