Rather than putting the Water Filler on deck, I ran it up alongside of the dagger board trunk, high enough so it will never spill over. also made it much easier to add water to the tank from my water maker. I run the water maker into a 5 gallon s/s milk bucket and use a meter to check it for purity, then taste it. Never a problem. Simple!
geneWj
