I am continuing with my slow but steady move toward SSB. I had two sintered bronze ground plates attached to the underside of the hull a couple of years ago, and I found a used SEA 230 tuner and am now about to start attaching a 3" copper strap to fuel tank, water tanks, toe rail, etc. What I am unclear about is: should these straps go the tuner and then have one copper strap go to the ground plate (one ground plate is attached to the other with a 3" copper strap) or should all the straps go to the ground plate and have one go from the ground plate to the tuner. Thank you, as always, for you thoughts.
Sign;
Confused as well as freezing in Miami
(aka Capt. Ron)
