You can't reuse swages. Also if you're putting an random wire antenna up at the SSCA gam they were actually saying using only one insulator. Don't use one on the bottom; that is if the tang on the bottom isn't grounded. And if it is unground it. We used the Hayn fittings and they're suppose to somehow be connected that they can't split into two.
Have fun.
Fair Winds
