Did some web research on it this AM
There are pros and cons about greasing the taper, but the argument against is that the key is not supposed to be the principal method of preventing rotation, and could cause shaft failure from shock loading -- they say a proper taper fit will hold the prop and the key is there only as a guide and backup. Some also argue that the grease could interfere with proper fit of the machined surfaces.
