is the general thinking. Machine tools use tapered spindles (e.g. Cat 40) to mount cutting tools, and the taper fit is expected to transmit the torque. A prop shaft is considerably smaller for the same or more torque but I suppose the principle is the same. I put light oil on the taper just to make sure everything seats correctly, assuming any excess will squeeze out.
