Shouldn't be any need for it...
'Cuz muriatic acid is only needed to dissolve really heavy sea water calcium carbonate buildup...V/Flush toilets use fresh water. If you're concerned about urine crystals and/or hard water minerals, flush a cupful of distilled white vinegar once a week. And use a bit more water to flush.
SeaLand's claim that the V/Flush can use "as little as" 1 pint of flush water is VERY carefully worded. If only urine is flushed...no water added to the bowl first, no TP either...then yes, you CAN get away with that little, at least for a few flushes. But if you do much of that, unless you want odor, at least once a day you need to run at least half a bowl of clean water through it to rinse out the system. It's also advisable to add at least half a bowl of water ahead of solids or any TP (iow, every time a female uses the toilet)...that's a quart or more. It's also essential to leave the pedal down for at least 7-10 seconds after the bowl is empty to rinse out the pump and duckbills--to prevent a buildup in the pump or bits of waste or TP from becoming stuck in a duckbill, creating one of those pesky air leaks that causes the pump to cycle for no reason...at least another quart. And if you don't want permeated hoses, it's a very good idea--last thing before the boat will sit (or at least once a week if you're living aboard)--to fill the bowl to the rim with clean water and flush it through to thoroughly rinse out the vacuum tank, hoses and pump...'cuz suction splatters waste all over 'em and the flush water flow isn't sufficient to completely fill the hoses. So, averaged out over a week, the VacuFlush actually NEEDS about the same amount of flush water that most other pressurized flush water toilets need: about .5 gal. If y you're using much less than that, you're asking for problems.
Btw...I had V/Flush toilets on my last two boats and was also a dealer for nearly 10 years...so I'm INTIMATELY acquainted with 'em...what keeps 'em working trouble-free and what doesn't.
