Return to Index
Read Responses
Make a mount out of Starboard. Work with the same tools as wood.
In Response To:
Cutting a hole in plastic box
Regular plastic box isn't going to hold up.
couple ideas...
Can't you clamp a piece of wood inside?
I think I'd pass on the plastic. UV will kill it way too soon.
I drilled the plastic..
The dimensions you specified are just about the same...
I used brightside
There are plastic paints on the market specificallly to "fuse" to plastic.
Why not make it out of teak...
