That would still involve more than one GFCI
I'm not clear what you intended when you wrote "plugging the inverter into shore power with an extension cord right to the dock outlet". That would fry the inverter. I assume you meant to plug it into the external shore power outlet on the boat?
That would still involve more than one GFCI. If I plugged it into the shore power inlet I would only change which side of the shore power breaker panel the second GFCI is on, but there would still be 2 GFCI's in series, and that was my original question: Whether 2 GFCI's should cause one to trip?
