mine a Charleston spar, 60 feet, Tartan 40. Awlgripped maybe 10 years ago, it's not in bad shape, but not great. A few areas of surface corrosion at the fittings, a few scrathces, it comes down every year. I suspect all the fittings need to come off, a fair bit of prep & fair & grind, coats of primer, coats of paint, coats of clear coat. Imron or Awlgrip ? I wonder what the cost for a yard/rigger would be, not sure I have the time ?
thanks, cheers, John
