Return to Index
Read Responses
Since you are connecting to a thru hull...
In Response To:
radio grounding
a fat stranded copper cable will also work. Something like welding cable. Has to be stranded.
radio grounding
hey rick! have an idea...
roof
OK
Aluminum duct tape (all metal) will work in a pinch and it's wide flat surface will actually be better than
If you have some RG-8 coax you could strip the braid out of that.
Just use the braid of the coax.
