If you have some RG-8 coax you could strip the braid out of that.
As Ron says, some flat copper tape would be better. Around here you can get copper flashing at a building or roofing supplier but I guess that's not an option where you are. I wouldn't expect aluminum to last very long but it would do in a pinch.
