Return to Index
Read Responses
If you need to
In Response To:
yes sounds like soleniod issues
You can manually jump the solenoid to get the anchor up or down until you replace the solenoid.
SL windlass question
Solenoid?
If you need to
Careful -- you are trying to control the
could have a bad spot on the armature
thanks for the advice
Brushes? Sometimes they get stuck.
Oh, and brushes wear out and need replacement....
What model is it?
I can't identify
I can provide you with a manual if you wish...
SL
looks pretty close to this model
That is a Horizon...
Buk - I would appreciate an owner's manual if
