Return to Index
Read Responses
looks pretty close to this model
In Response To:
What model is it?
SL windlass question
Solenoid?
yes sounds like soleniod issues
If you need to
Careful -- you are trying to control the
could have a bad spot on the armature
thanks for the advice
Brushes? Sometimes they get stuck.
Oh, and brushes wear out and need replacement....
What model is it?
I can't identify
I can provide you with a manual if you wish...
SL
That is a Horizon...
Buk - I would appreciate an owner's manual if
