Not familiar with Yamaha
I'm not familiar with the small Yamahas, but all the small motors are very similar. Should not be any major deal to change the seal. You should be able to use a small pick of some kind to pull the old seal and anything of the proper diameter to drive the new one in. I would be sure to change the impeller while at it.
