source for exhaust riser Yanmar 2QM20?
I've done some quick net searches and it appears that the exhaust riser is under about $500.... Of course these were quick searches.
Can anyone confirm this? Any good links for these parts?
Survey has shown that the exhaust riser has some pin hole leaks and the bilge pump needs to be replaced. (bad combination of potential failure items, no doubt)
But what from what I have seen on the net, these items should be well under 1 boat buck, altogether. (of course labor alone to replace them could be considerably higher... depending on the use of hired labor or personal 6 pack factor)
Comments? Anyone? Bueller?
