Return to Index
Read Responses
You really wouldn't want to be cooling portions of your hull to -75 degrees, or whatever. You'd be streessing the tabs
In Response To:
I don't think it is the cold that is the "tool."
And the rest of the hull. Plastic expands and contracts a lot. That wouldn't be good, in my opinion.
Dry ice bottom blasting
Yeah, I imagine it would make FRP brittle.
Yes, (I'm not sure about the efficacy of that) but I was concerned that someone might let it be done to their hull.
