Return to Index
Read Responses
Yeah, I imagine it would make FRP brittle.
In Response To:
You really wouldn't want to be cooling portions of your hull to -75 degrees, or whatever. You'd be streessing the tabs
But this was done on steel hull according to Craig.
Dry ice bottom blasting
I don't think it is the cold that is the "tool."
Yes, (I'm not sure about the efficacy of that) but I was concerned that someone might let it be done to their hull.
