I don't thing those are waterproof?
In Response To: I am an industrial electrician ()
You might try a 30 amp shorepower outlet -- then use a 110V 15Amp adapter with your power tool pluged into it.
I think that if you mount it vertically, it will work (but use the screw cover to seal it).
It's pretty big, Brian.
I think Tom's suggestion makes a lot of sense. Can't you put an outlet in one of the deck lockers. (not the propane one ;^) )
