partial refinishing
In Response To: Cabin sole refinishing ()
the only problem with doing it that way is that there may be some uneven discoloration from where there was wear on bare wood. It there is no bare wood, then you just have to rough it up. A heavy scotchbrite pad will give it some tooth and not take off a lot of the base finish.
You can always test a small spot first.
rich
